I've had a few people ask why I'm going from 8-lug back to 6-lug... Well, the primary reason is the 8-lug Dana 44 hubs set the wheels out 1-1/4" wider on each side, so 2.5" of more track width.
No no no, the front is too wide when it's 8 lug, it's not about finding a width matching axle.Seems to me that a pair of 2" spacers would have gotten less work than re-gearing another rear.
But, hey . . . A project is a project
And looking forward to the end results![]()
The front axle is just too wide, tires stick out too far, and ultimately rub the bumper/fender when flexing.Yes, the spacers are for the rear.
Although, if the front axle width causes issues with tire clearance, that makes sense. Then again, I am probably missing something . . .![]()
I wouldn't do a body lift. It's not about going higher, it's all about the width of the tires past the body.Gotcha. That does make sense.
Although . . . You sure a body lift is not easier?![]()
200LBS but i re-used it multiple times.Its looking awesome so far.
How much media did you go through for the whole frame?
Knowing Dave... it'll be along directly... LOLAnd where is the new duramax build thread?!
