red
Being a lake bum in Texas
Alright well here goes, starting from the bottom and building all the way up.
The truck is my 1987 chevy k30, I'm the 2nd owner. Original owner for the most part had it as a toy, pulled a 2 horse trailer from time to time and that was about it so nothing difficult for this truck. The flatbed, 35" tires, and 6" lift were all on it when I got the truck. Originally powered by a 454 with a sm465 4 speed manual trans.
I plan to keep this truck for a very, very long time. So it must be built to last and handle just about anything I put it through. I want the truck to be able to handle towing a trailer up to about 14k pounds (Little less but better to have the truck overbuilt) on a gooseneck hitch. I take the truck offroad up in the mountains as you can tell by the pics, tend to go places that most say it should never be able to go :hihi: while carrying a few people and gear.
So things the truck needs to be able to meet:
1. solid frame
2. ground clearance
3. traction
4. power
5. brakes
6. down right reliable
7. reasonable fuel economy
The truck had good power with the stock drivetrain, but I wanted more and much better fuel economy. Originally started with going for a 12 valve cummins mated to an nv4500 5 speed manual with np205 tcase. Ran into alot of nightmares dealing with discontinued parts from dodge and the trans/tcase and got fed up with all the bs so went back to a big block. had the 454 bored .30 over, custom cam for low-mid range torque, long tube headers, dual plane intake, and single 750cfm carb. Plenty of power and should be reliable. Problem (as expected), fuel economy was horrid for a truck that does a fair amount of highway driving at only 7mpg. Loaded or empty. So the search continued for an engine that would meet the goal while keeping the drivetrain setup simple. Decided to go with a mechanical IP 6.5 setup for towing and reliability http://www.thetruckstop.us/forum/showthread.php?34325-motors-motors-motors
1. solid frame
2. ground clearance
3. traction
4. power
5. brakes
