NintendoKD
http://www.ebay.com/itm/TH400-Mechanical-Modulator-Replaces-Vacuum-Cable-/261077221582
here is one, not called a mechanical kickdown, but a modulator, anyone wanting to use a chevy, or allison trans with a diesel, or using a forced induction application will need one. I am not buying that one, just using it as an example because of the nice pretty picture. I have some more pictures.
tried to get the quick connector off of the coolant passage tube, and it just broke off, due to excessive electrolysis. Even worse still, I tried to use an extractor to get the rest out with the help of a torch, and ended up melting the rest of it in place. Now I can just drill and tap it to size.
wrapped my cross pipe.
and both manifolds
going to do the turbo too, if I can get the bolts unfroze from the housing.
here is the turbo and intercooler, just as a reference. it is small, but I believe it will be plenty efficient enough.
engine de-greasing 101, use dollar store oven cleaner. BAM!
and both manifolds
