NintendoKD
pulled the 350 sbc out and am going to drop in a 6.5 from a 95 chevy 1500 with 115k miles on the clock.
I am going out to the pick n pull tomorrow to see what i can see in terms of 6.5 trucks, I need an injector pump lines and a torque converter., as well as the wg actuator from a 6.5 from 92/93' or I'll end up buying my own. I am going to end up buying a rebuild/seal kit and rebuild my pump "these things aren't cheap" I have access to a lathe and mill, and am looking at making sleeves for the fuel pistons in the rotor to make it last a little longer. I am also doing an egr delete. I am not trying to make stupid power here, just reliability, bone stock, I would like to go vacuum less, however, I have vacuum booster and a th400 on the truck with the vacuum kickdown. I am getting out of the military and need this beast to make it all the way across the country. fuel economy would be great, but is not necessary. I need to spend as little as possible and get done quick, so the odds are against me, just like when I did this " www.battleofthebuilds.com "
wish me luck, I'll have some updates soon. I have to wait till wed to get paid and get some more work dfone on the engine. needs cleaned, which I'll accomplish with a can of good ol dollar store oven cleaner, works miracles this stuff for tough grease/oil/sludge used it on an oil pan that was full of parafin sludge and a couple hous later it all came right out.
