That is what I was thinking too. that also would throw the balance off some. the weight would still be in the general area, maybe about 15-20 deg off. might be enough to cause a vibration that would alarm a fella but so so much to cause an auto self destruct on first start up.Maybe flex plate installed backside forwards
Dont know if it could happen on these engines.
If so, that could cause some out of conformity![]()
If the flexplate has that ever so slight of a ridge around the center cranking shaft hole like some FPs I have seen, then tightening down the bolts would cause the FP to sort of tweak off and not run true.But how does installed "wrong side out" (if at all possible) account for the very noticeable wobble in the edge of the flexplate we saw in his video, let alone how that would affect the starter pinion gear to ring gear engagement enmeshment depth when he engaged the starter or how it would affect disengagement of the pinion when it started and he let off the key?
I'm still leaning toward a bent/warped flexplate or a crack in the center/arm of the flexplate accounting for the vibration.
Of course, we won't know anything until @Scott_2255 gets back on here with what he found after dropping the transmission to see why the flexplate has that wobble.
That FP in the pic; is the engine out and the FP removed ?I looked at my flexplate. It looks like it is impossible to mount incorrectly. The counterweight actually faces the engine block and the dowell insures that it only fits one way. Forgot to mention this is a 6.2 but assume 6.5 is no different!
I think he thought you were the op. Btw, people often install the flexplate backwards. It will bolt up but depending how bad the curl is from stamping the center hole they will go on part way to all the way. Sometimes go on slightly crooked, rubbing issue can occur, starter alignment issues can occur. Often this breaks the flex plate if operated this way.I am not sure what that would do for me! It is @Scott_2255 that has the problems. I could lay this FP on a flat surface and I don't see any issues with mine.
