Yes, I have TSP’s 18:1 coated pistons.
But I am beginning with fuel at 110 cc and looking at hx40 running enough bikst to offset the compression drop easily.
Balanced rotating assy, gear drive, german bosch marines (2 sets to swap in & out to find optimal pressure), p400 heads, roller rockers- still considering 1.7 vs 1.6.
Better valve springs& lifters, etc.
But running the oil squirters is such a proven help for boosted engines that it isn’t even a question for any new engines built by mfrs.
I’m not 100% on it but leaning very strongly towards them.
Yeah- tooling nicks were a thing for sure, but high speed mass production error isn’t really a concern for me. I would be doing this by hand (jig set most likely) and taking my time.
Idk what years had them, what didn’t. But I have the May 99 van engine to compare and determine angles, etc if I go with it (provided it has them).
If GM ended up abandoning it, I would be comfortable not running them. But the fact they are still in use in the optimizers tells me their failure rate couldn’t have been horrible.
