Husker6.5
I could swear that my '94 didn't have them when I had to put two new heads on. Pulled the block heater on the driver's side (had to any way, it had burned out) to drain it, but looked and didn't see a pipe plug. Didn't pull the starter to look behind there on the passenger side, after pulling that head, used the shop vac to suck the water (with a wee pinch of antifreeze in it, remember the saga of valve seat cracks WITH GM's "miracle cure tablets" added to it and going through 8 gallons of water in 60 miles? [Warning to Neal who insists the tablets will fix his head/head gasket leak, they don't. They just prolong temporarily the inevitable and expensive cracked head replacement.] I pretty much had straight water in the system.) off of the piston heads and out of the cylinders. I pretty much had straight water in the system by that point, anyhow. I haven't looked at my '98 to see if there are pipe plugs in the block for draining. Perhaps somebody could post a definitive (by block casting number/model year) listing of which 6.5's have block drain plugs and which ones don't? Or am I just becoming a senile, blind old man who couldn't see the obvious block drain plug 6" away from the block heater I was removing from the frost plug hole 10 years ago!
