- Staff
- #21
Just make sure you take pictures and ask for advice... we've seen lots of not-so-good PMD units... we can help you to not follow that trend.
Guess this helps to seal the deal on what my issue is. Here is a picture of what i have.
Am I the only one that doesn't see the ground on the IP? That's a pretty important ground to keep on the IP....
Just a follow up. Got the PMD today. Pluged it in to test and to move truck from middle of driveway. And she hesitated a little but then fired to life. So as you all suspected it was the PMD. Now to fix the ground issue, install PMD correctly and replace the bad # 7 injector but have to put ford 6.0 back together first (don't ask, known injector issue :>).
Thanks again all!!!!
