JamesKing1995TurboDiesel6
Hey Gang! I've read so many of these but never pisted. Ive hoped to find a solution to my issue on 1995 Chevy Cheyenne 3500, but every situation was slightly different so Im finally taking the plunge. Im a fair mechanic and very good with fixing stuff so I think together, we will do awesome at helping me once and for all!
Truck Background:
90k miles
All stock
PMD Relocation Done (bumper location)
Lift pymp done by dumbbells and cut orig lines. I redid them using gas line and 2 clamps per connection.
Also... the blue wire for the lift seemd to have broke somewhereso they also tokk a damn speaker wite and ran to the fuse box. It does come on with key, but stays on the whole time. Not sure if that is ok.
New parts all are less than a week old and are as follows...
1. PMD
2. Alternator
3. Batteries
4. Fuel filter
5. Lift pump
6. Intake sensor (top of intake location)
7. Glow plug Relay
8. Air filter
9. I also replaced a break part non valueable fir my issue im sure but in transparency its now added LOL
I think thats it?
___________________________________
After reset these are the freshest codes i have...
1. #14 (Engine coolant temp. sensor)
2. #31 (EGR control pressure)
3. #42 (Fuel temp. Circuit low)
4. #57 (PCM 5-VOLT short)
5. #62 (Turbo Charger boost censor High)
Issue(s) and time line...
Truck has been great. Always started and ran although it always had PMD issues.. revving up, very little stalling but it has a bit, and as far as i know nothin major.
After 5 yrs owning and most of the time sitting like a good work truck ready for a job I had to start using as a primary vehicle about a year agi. Thats when all hell broke loose. Ive spent hours of time rwading, begging, searching mechanics and replacing stuff. Heres why...
Truck last year stalls.. and stalls.. and stalls.. buy 2 (3 year warrenty) Walmart batteries for this exact application. Batteries die so fast! And charge, and charge... over and over.... Return batteries... 2 new ones same store... one year batteries this time... Same issue. Batteries seem weak.. drain fast, and didnt last long. Tested them. 2v to each cell. Charge up fine... so im stilk using them . The batteries are all less than one year old. But i only crank 3 times for like 10 sec. Each time and i have to recharge batteries AGAIN.
STALLING...
Truck starts to stall more and more as i drive it... Been stranded 14 times this summer and many times last winter. Fig out last winter to jump the Glow Relay (easy fast fix) and it started right back up.
THIS MONTH...
Finally, the truck is not trustworthy, not drivable and im so confused. When the glow light comes on now, its short and not the typical 5 to 10 seconds as always has been. I cant stress that enough. Ive read 300 posts where a guy is adding this as an issue and others say... " well thats no issue... it will...with climate blah blah..." NO! THIS is a major issue in my situation specifically. I believe may be the root cause of the other (stalling) issue as well but i cant be sure.
Every so often, i eill get a 10 sec light to stay on and I always say ouy loud... "Bet she fires up no prob now..." AND EVERY TIME IT FIRES AND RUNS.
This glow plug light is timed by a sensor i guess? Maybe also ECM? This brings me to another clue.
Flush and fill...
I did a bad thing. I flyshed and only used water. I live in Texas and it was only two months ago so not a chance this summer that it was to cold or froze and i have NOT over heated the truck as it just doesnt run. The flush was just my attempt at a cheap possible fix.
I think now all the sudden im leaking out of my damg water pump so i may need that replaced now too...
Noticed water without Anti freeze makes pretty orange rust in the system so i wilk fill properly once the truck runs and i replace pump if its indeed shot.
Ive heard and read of a timer for the glow plug light and connected parts but seen no proof of this. My idea is that this light is directly controlled by the brain and thats that. I'm actually starting to suspect that the brain (ECM?) may be my issue. Again i just dont know.
Truck runs great WHEN IT STARTS. BUT... While driving, the truck does this...
1. Stalls as if the key were turned off
2. Hard starts
3. Sometimes Rev up by its self
(This is why i replaced the PMD THIS WEEK. I BOUGHT 2 NEW ONES.. YES 2) LOL
4. F@ST cycling glow plug light
5. Hard on batteries and/ or the Walmart brand batteries are truely a rip off. I get that most eill agree with that but... This truck ALWAYS starts if that plug light stays lit properly so im ruling out dead batteries for goid! Ive done started this truck with the origonal batteries from purchase with 3 bad cells before and i know it will start even with a weak battery.
I aldo know that weak batteries can be a very trucky hidden p.i.t.a. so i never say never...
Thats why i bought 2 new ones just so we can skip the guy who is definitely going to chime in the thread and say... DID YA CHEC FRESH BATTERIES? SOME TIMES..."
The brand new PMD BOXES will hopefully rule out the guy who will definitely be chiming in with... " Brother, you need to replace and relocate that PMD man... Im tellin ya... trust me..."
I want to even see if we can skip the giy who will say... "Guy, that glow light thingy...it dont matter.. as long as you have...."
All 3 are a major time killer here. I need to figure out how to get my light to stay on. As ive said, its not the Plug Solinoid or as also called GLOW plug Relay. My old one is good. But i replaced with brand new one yesterday just to eliminate that giys advice too..
Now we have all the data i can provide...
I started it by pull start last week. Heres what i got... Black smoke. I usually dont see that cobbing mess out of my pipes EVER. Its so thin i barely notice usually. This was noticable. Not out of control, but just more than usual. So that may be another clue or maybe just burning out all the gass from so many no starts and trying to pull start it for about 10 miles? I only drove it home and that was a mile that day. Last week that is... i parked it and i let it run. It sounded so sexy. Just clug clug clug... no hesitation no bumps.. just pure lapping.
Then i shut it off.. restarted just like new... shut off.. restarted hour later just like new...
Next day... DOA
NO start.. batteries dead.. back to charging and putting in more cell acid... Im wore out yall. I need help. This is my only truck..only transportation. Im all by myself after a bad divorce and im now 1600 miles from my home town. I live here permanently so that wont change but i have no one to call for rides. I have , HAVE to fig this out.
Please can anyone feel me on that and give me some advice?
Thanks gang! I love you dudes! Even the few Battery, PMD, and Relay guys! Haha, yall are right in some threads... just maybe not this ine.
Take care
Truck Background:
90k miles
All stock
1. PMD
2. Alternator
3. Batteries
4. Fuel filter
5. Lift pump
7. Glow plug Relay
8. Air filter
I think thats it?
STALLING...
THIS MONTH...
Flush and fill...
2. Hard starts
Next day... DOA
Take care
