Just sent that piston to WW, he'll use it sooner or later
Yeah. A sad ending for that motor home.Nomination for @3bals for this year.
Goodness, gracious 3bals RV a-fire!
Breaking sad news. Just received a message from Jody @3bals as to why he didn't make it into Lincoln yesterday evening on he and his wife's vacation. At MM74 on I-80 in Iowa yesterday afternoon there was a fire in the engine compartment of his P-30 chassis-based motorhome that quickly spread...www.thetruckstop.us
Yeah, there's a ton of work and $$$ wrapped up in that P400, not to mention the Road Ripper XHD 4L80E behind it.And the k5. Dang man. Hope he gets a ton from insurance, and hope someone can rescue that p400.
Lets see, Iowa is like 24 hours drive time from here...
There was a load of stuff done to that P400, iirc, from the build thread Jody did a few years back when the GM 6.5 barfed that rocker mount and it died here in Lincoln and he had AAA tow it back to the Twin Cities. You should probably PM @3bals directly, instead of hoping he sees the comment on here @Twisted Steel Performance .I'd be interested in the motor if it can be removed by itself and leave the rest.
www.instagram.com
That Your enjun ?Login • Instagram
Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.www.instagram.com
That Your enjun ?
Because there is a coolant passage between the valve openings in the head to help keep the seat area between the valves cool. When the head cracks between the valves, it cracks into that coolant passage. Thus when running, the compression leaks into the cooling system because compression presure is well past 400psi while cooling system pressure is 15psi. After shutdown, the hot, pressurized coolant seeps through the cracks and into those depressurized cylinders and gives you the white, billowing, acrid-sweet smelling clouds out the tailpipe at cold start up that screams "blown head gasket or cracked heads".Umm school me here, I’m confused how cracks between valves caused compression leaking into coolant..?
Well, two options. New heads or the brass tube inserts into the coolant passages. Assuming the heads aren't too warped.Noticed a small stream of bubbles in the expansion tank. Tore it down this week and SURPRISE, four matching cracks in the head! Can't wait to pull the other side!
