93detroit
I push this motor hard, but water temps and egt were kept in the "safe" zone. Full crosshatch and no scuffing in the bores.
Ohh ok, thanks!Because there is a coolant passage between the valve openings in the head to help keep the seat area between the valves cool. When the head cracks between the valves, it cracks into that coolant passage. Thus when running, the compression leaks into the cooling system because compression presure is well past 400psi while cooling system pressure is 15psi. After shutdown, the hot, pressurized coolant seeps through the cracks and into those depressurized cylinders and gives you the white, billowing, acrid-sweet smelling clouds out the tailpipe at cold start up that screams "blown head gasket or cracked heads".
How long do you think that pos lasts? They can never get a weld bond completely through the break.Oh good! Glad he spray painted it because it was sure to rust inside the oil pan!
Coming soon to an E-Bay site
More likely to show up on billionaire Bezos's site first.Coming soon to an E-Bay site
