great white
I've read that you need a custom oil pan for the P 400 to fit over the front axle of a 4wd.
Correct.
Simple, It's an easy swap, requires no electronics and 12v's can be had cheap an easily and you can easily get nice HP from them with little work and aside from the KDP issue which can be fixed with a 30$ kit it's a pretty indestructable engine.One last gripe and I'm done: why on earth does everyone love the Cummins swap? I see it a lot on the 73-87 boards. I fully understand you can get a lot of power out of them if you've got the money. But stock they are nothing to brag about, and either stock or modded they sound like crap. I would not take a nice comfortable smooth riding Chevy and make it sound like a piece of construction equipment. I absolutely hate the sound of a piped inline 6. Sounds pitiful. Certainly couldn't stand to listen to one groaning away all night plowing snow.
Correct.
The drawbacks to the 4X4 EXCURSIONS is that FORD got the bright idea to install softer springs in the front end and lower it down from the SUPER DUTIES. Since they lowered it down they had to install lesser arch rear springs which meant they had to be very stiff to hold the extra rear weight of the X and strill be able to hold up tongue weight. A F-350 SRW truck has 385 LB rear springs where as an EXCURSION has 410 LB springs. Quite a few of the guys over at TDS have swapped out the EXCURSION springs for F-250 front and rear springs along with RANCH or BILSTEIN shocks, larger sway bars, and a set of 03+ bump stops in the front end(in 03 FORD went to a TIMBREN style bump stop in teh front end since the X sat so low it rode on the bump stops). If it has the 7.3L it will have the 4R100 trans in it which is pretty stout, but the torque converters in them are weak and the FORD valve body gives way to soft of a shift. And of course the 7.3L PS has injector problems if the oil isn't changed often, the wonderful high pressure oil crossover line that leaks or pops, and the stock high pressure oil pump can't keep up with much of a tune most of the time.
I almost bought an EXCURSION until I rode in one, after that my BURB got a DURAMAX.
I have a good friend who's a 7.3 PS fan. In addition to all the negatives posted here, he says there is either a camshaft position sensor or crankshaft position sensor that is prone to going out. When it goes, the engine will not run. It's a $50 part and he always keeps one in his glove box. Sort of the 7.3 PS equivalent of the PMD for the 6.5 TD.
And is there a source for them?
Have to make your own.
I don't really have much to say about the Duramax swap in a Suburban. Never seen one. I'd probably like it. I think a 6.5 with all the standard upgrades would be better: ie, more reliable and a lot cheaper. If a modded 6.5 is not enough motor for what you need to pull, you're probably not going to be using a Suburban anyway. That's why hotshots are all crewcab duallies anyway. And you can get them with a Duramax.
That is a recall item and ford will fix it for free. I had to change mine before the recall. It took 10 mins.I have a good friend who's a 7.3 PS fan. In addition to all the negatives posted here, he says there is either a camshaft position sensor or crankshaft position sensor that is prone to going out. When it goes, the engine will not run. It's a $50 part and he always keeps one in his glove box. Sort of the 7.3 PS equivalent of the PMD for the 6.5 TD.
I think that's a matter of opinion, it's not uncommon to see 300K + Duramaxs out on the road with no major problems.
