ak diesel driver
6.5 driver
I thought the glow time seemed a bit short
Those are some impressive videos. Seriously worthy of the technical reference how too section.
There isn't anything wrong with that engine.
Blowby changes from cold to hot engines - check it both ways. All I can think of that would be different unless the CDR stuck closed or a hose to it was pinched. (Gold tuna can, CDR, Crankcase Depression Regulator, goes by hose to the oil fill.)
I would double check the crankshaft vibration damper from the background noise.
I assume a hot engine for the retard lever test? Possible you have a worn or sticking advance piston in the pump esp. after the timing retard test smokes so much afterwards. Injectors combine to amplify problems in the pump where worn injectors are worse. Light load going down a hill can bring on white smoke. Generally the amount of white smoke you have, I assume it smells like diesel, is an issue if the last video was on a hot engine. Otherwise you put the fire out (precups too cold to light the fuel) on a cold engine.
I do not know what engines had the EPR, exhaust pressure regulator on the driver's side. It makes a difference by warming up the intake with EGR cross flow - at least it did in our 1988 1/2t.
With working glow plugs I would suspect pissing/sticking injectors then look at the IP. Especially with the long crank time. Do you have 100 engine RPM minimum when cranking cold and 150 hot?
They make injector nozzles in both places or transitioned (I forget), you want the German ones. Again a local Stanadyne diesel shop can rebuild your injectors and threads in the body don't matter at that point.
Bosch Duraterm, yes.
I do recommend getting and using the spring clamps on the return lines despite claims the new hose doesn't need them. Mine and a rare couple others have had leaks and lines blow off without them.
The best-Bosch fuel return line is available at Mercedes Benz dealerships really cheap- it is for their idi diesels like any 1980s 300d. Buy by the foot.
that link for the glows was the correct one. they don't say duraterm on them
This engine with the 6.2 heads and long 6.2 injectors wouldn't work with your 6.5 stuff. It wouldn't clear the injectors, the head injector threads do not allow 6.5 shorter injectors, and the AC box doesn't clear. You will need a banks manifold from Leroy diesel and that will solve most of the fitment issues.
The 6.5 turbo will cost you ~5 MPG all the time going from 20 MPG to 15 MPG. The Banks turbo is also small. Then the 6.2 precups start to be a restriction with bigger turbo's.
KR services on Ebay are a solid company.
That thing does smoke, even my van on WMO doesn't smoke like that, lol.
People have double stacked exhaust gaskets so the turbo will clear the injectors.
Why do you keep saying a turbo will cost MPG? NO WAY will he lose 5 mpg, he actually might pick up 5 mpg, not lose it.
