ak diesel driver
6.5 driver
any history on it?
it has an external oil coolerI don’t know if the 84 had a oil cooler on it or not but if it did I would seriously consider replacing the oil cooler and lines.
Very cheap I really need a 6.5 IP that's mechanicalPrice?
I'll sell real cheap would you happen to have a 6.5 IP that's mechanical?Price?
can I use 6.2 IP on 6.5 turbo?I have the sought after one that need built on the shelf but I am hoarding! lol Along with the crossover. But keeping in case the burb goes mechanical. I have a mech 6.2 as well so I have to stash parts as I find them!
Thanks I hope the pump is good I have a question when u turn the pump should it be easy to turn or have more resistance?Yes you can. You will want to turn the fuel screw up on it though. It will Bolt up just like the 6.5 IP. If you are using the gm turbo then it will work fine until you decide to upgrade the pump or turbo.
I can turn it by hand easilyIt shpuld not be hard to turn. A regular small allen wrench will do it easily.
