Does anyone know anything about the roosamaster db2-4091 ?
There are some db pumps that wont do well.
@Jaryd I believe the HVAC system uses vacuum in the 80's.
Used banks turbo setup is the easy button as they fit. One may be for sale here.
https://phoenix.craigslist.org/evl/pts/d/gm-65-diesel-engine/6753040343.html
That is the 6.5td I bought to replace the 6.2Looks like an A6 compressor! Some debate awhile ago on here as to if the A6 was ever put on a 6.2. That big displacement cast iron Tank of a compressor will perform better than the newer one that you don't have (missing in pic) on the 6.5. Lifetime of the A6 clutch not so much as it has to get a lot of compresser mass spinning. Thanks for confirming my memory as to what I recalled our 1988 6.2 had on it.
Yeah probably not gonna use itView attachment 54783
A6 compressor under the hood here is what I was referring too, circled. It looks like the 6.5 doesn't have an AC compressor on it.
I have all the parts for 6.5 and compressorYeah probably not gonna use it
It's a 3500 dually wreckerIs this an HD truck? AC box might sit differently than a non HD
