ak diesel driver
6.5 driver
Need to look at the pickups or tone wheel to see if the signal source could be swapped ie the cps would need half
as many
as many
Just brain storming here... most distributor pickups for a v8 gasser have 8 lobes, one for each cylinder to send signal to fire the coil plus give rpm signal to a tach. iirc though I might me totally wrong here, doesn't the 6.5 tone wheel on the snout of the crank have 4 lobes for the CPS? maybe, just maybe the oil pump drive cam sensor was build the same as the gasser distributor pickup coil. I was never able to get any kind of signal from the oil pump drive sensor on mine plus it was puking oil from the connector. not sure if it's a candidate to be dissected.Need to look at the pickups or tone wheel to see if the signal source could be swapped ie the cps would need half
as many
You are right. No voltage means highest line pressure. The TCM controls that function through variable width to the force motor pressure control solenoid. Higher voltage means less pressure to the clutches. Think of it as a safety mechanism to prevent clutch slippage. Now find out why the TCM is doing this. One of the most common causes is the torque converter clutch slippage.Back probing pins C and D on the trans connector revealed 11-12 volts with the key on. if disconnecting the connector allows the trans to run at full pressure (no voltage to the solenoid) then I would assume when voltage is applied it should lower line pressure.
Looking up the EPC online, there not a cheap replacement, the GM one is a little over $200. I want to make sure this is the issue before tearing into it.
TPS is the best place to start. Proper adjustment using a test block gage .646.Well after all the work that went into fitting a factory TPS on the truck and seeing that it reaches 5v before a full sweep of the throttle at WOT I have found out the trans is shifting harder than before I started. before I drop the pan and attack the PCS I need to go back to the drawing board on this TPS. need to find something that doesn't reach 5v until the throttle is at WOT and will rest at about 0.5v at idle.
yesterday I did check the cable operated TPS with my meter and it does work at full sweep but the cable only has about 2 inches of travel where I need more to allow the IP to do a full sweep. That or a shorter arm on the throttle shaft. I pulled the box apart on it and see that I could change the spring so it doesn't add to the pedal return resistance. If I can come up with a shorter arm for the shaft I can make it work.
Once I figure this out and resolve TPS issues, then I can dive into the trans.
Just what is the EPC?@GenBiltstein The TCU is an aftermarket EZ-TCI TCU which I have not been able to get much information from the mfg unfortunately. and very limited data from it on the display.
The only fail safe the TCU has is if it detects an issue it will go into limp mode and stay in 2nd gear. it shows no faults. the main issue I believe is it doesn't have the ability to read what the EPC is doing, only send commands.
Retrieve DTCs and make sure that you are not getting one of those DTC 21 or DTC 22. TPS low or high voltage.Well after all the work that went into fitting a factory TPS on the truck and seeing that it reaches 5v before a full sweep of the throttle at WOT I have found out the trans is shifting harder than before I started. before I drop the pan and attack the PCS I need to go back to the drawing board on this TPS. need to find something that doesn't reach 5v until the throttle is at WOT and will rest at about 0.5v at idle.
EPC = Electronic Pressure Control. other names for it is a PCS = pressure control solenoid.Just what is the EPC?
the TCM is not GM.Retrieve DTCs and make sure that you are not getting one of those DTC 21 or DTC 22. TPS low or high voltage.
NIce!Just wanted to post an update since the weekend. so far after swapping in the EPC solenoid from the donor, the truck has been shifting perfectly fine.
I've got my parts list together to order the new solenoid, pan gasket and new fluid/filter. I will continue to drive it a few days longer before I conclude this was the fix though.
