- Staff
- #61
The factory rockers are a good design, but high rpm's can lead to the trunion coming apart and the needles coming out. Under stock use they're fine, but its cheap to upgrade them to the captive design with a snap ring to prevent the bearings from working out under higher spring tensions/rpm's.Tonight I did the trunnion upgrade to the rocker arms. Apparently the factory needle bearings in the rockers can fail which not only means a rocker isn’t doing its job properly, but then you also have tiny needles floating around in your engine. I bought the kit from Brian Tooley Racing.
It has nice instructions.
View attachment 55773View attachment 55774
Here is an exploded view of a stock rocker after disassembly.
And here it is with the new parts instead.
It took a little over an hour for me to do all 16 rockers. Here’s a finished rocker plus some extras. It was nice to see they provided an extra bearing and a couple extra clips so you could make a mistake without having to order more parts. You can also see the new bolts and a 12 point socket for the bolts included in the kit. Pretty nice stuff.
