MrMarty51
Td is for teed into the vacuum hoses.
The boost gauge fittings on my truck are drilled into the back side of the upper manifold, the tube portion that the hose from the turbo connects to it.
The fitting can be installed anyplace in the upper intake manifold. Where ever is handiest.
If drilling without removing the upper manifold, be sure to fill the drilling bit with grease to keep shavings from falling into the manifold.
