A couple of questions.
Seems that this is a 2002 engine. Found diamond in the walley.
Real hard running sound at startup for a few seconds. What can cause this?
Nr 9 resistor in pmd.
Found a (what I think is) a boost fooler. Do not get any codes/engine light. Use manual wastegate spring.
9 psi.
Vacuum pump don't work. Egr vacuum line is of and same with boost vacuum.
But shouldn't it throw codes? I think it runs really good. No smoke.
But the sound at startup is deafening.
Uses fuel like a champ. 11 miles pr gallon. Litle high in a tahoe
9 psi.
