JiFaire
Land Mine Finder
Yep, the warm-weather folks are often absent in the heating threads, but they've got great ideas in the cooling threads!JiFaire, i definitely noticed that people posting on this thread are ranging from Alaska to the northern states which makes sense for obvious reasons.
Dylly said:As for hooking it up to the headlights, I agree, that could be a major issue, although when I had that brain wave, I was trying to think of something that would work with my command start, and I know for sure my headlights come on so now I need to find a different way of being able to tell the intake heater to start up without me being in the truck to flip a switch on and off.
You might not be far wrong... how about running a line from your headlights to a light-duty relay, then from there to a heavy-duty relay? You could run the ground from the light-duty relay to a dash switch so you could disable/enable the circuit at will; that would let you turn on the switch at night (with no power in the circuit) and when your command-start turned on your headlights, the heater would get energized. If you left the ground switch open, the little relay wouldn't work, and so neither would the big one.
Dylly said:Oh, I had one more comment to make on the intake air heater… I was reading somewhere online how the cummins’ intake heater works, and the way I understood is that if the PCM reads an intake temperature is below -18 degrees C it will run the element while the truck is running unless the intake temperature is above 15 degrees C… I could be misinterpreting the data though…. And that’s where my “run it constantly” idea came from.
Anyway, any thoughts and/or suggestions on the cooling system or intake heater will be much appreciated. Thanks again.
Given the amount of airflow, I wouldn't think this would be very efficient, and would put a big load on your alternator. JMHO.
We'll help with your cooling system in the spring (right now, I'm too cold to talk about anything but heat).
If the Tstats are working properly, if they are 195*, and if you cover up well, your 6.5 will keep you warm. Mine has been fine at -40, but without the winterfront, it is 'way too cool.
