dbrannon79
I'm getting there!
I wonder if you can find any numbers on the old seal or perhaps get the housing OD and shaft size for the seal ID and just find one by size. Napa usually can find one by the size in their paper catalogs.
Yeah, I just used a 2-jaw puller to remove it. It came off pretty easily. There's another version of the tone ring that has a smooth bore instead of the splined one like mine - I imagine that one is tougher to remove. The smooth bore tone ring is a little more readily available, but unfortunately it doesn't appear to be backward compatible.Thanks so much for sharing the details. How did you remove the tone ring for the output shaft? Regular two or 3 jaw puller? I remember there was a fellow on here a couple years ago struggling to rebuild the same unit and he couldn't seem to be able to remove the ring or read that to disassemble the manual said to split/ essentially destroy the part.
Did you re- use the clutch coil or were you able to find a replacement? That also seems to be an elusive part and I'd love to know where to get one if you found a legitimate source
I was able to find a number on the old seal, but it didn't help me with cross-referencing. I'm not sure the goons at the local Napa would be very helpful in trying to cross-refence this seal - it used to be Napa was where you went for better parts and service around here, but it seems they've dumbed themselves down with the same shlocks that work in the other places.I wonder if you can find any numbers on the old seal or perhaps get the housing OD and shaft size for the seal ID and just find one by size. Napa usually can find one by the size in their paper catalogs.
My gut feeling is their catalog isn’t correct and they can’t actually get the tone ring. The part I don’t get is why the order hasn’t been automatically cancelled though. Not a big deal, it’s just curious.Hopefully it Wasn’t shipping out of the Ca location
I have a dash that came out of a Suburban at the junkyard that's in good shape. Hopefully it lasts a while. Good to know there are reproductions available now.I never paid any attention but I had replaced the heater core in my 95 with one from the auto parts store a good while back due to it leaking. it's never had a good heater. my 93 will burn you out of the cab. I have never touch the 93 since I bought it last year. maybe this is my issue?
BTW what are you planning on with your dash? full reproduction replacement, custom build one, or trying to save on what you have?
I have found a couple of places that sell a complete ready to paint reproduction dash for this style, one is LMC truck and the other was a site I found online I can't remember what it was called. as for the design, since most all of the dash is mostly flat, I don't think it would take a lot of work to take measurements on the old dash and recreate it using wood. a full wooden dash would be cool to see in these trucks!
I prefer the 95+ dash, but this style has grown on me. I just use the screen on my phone for GPS, but a larger screen at the upper level of the dash would be nice.Now that is a gem there!
I love this style of dash, only thing I dislike is the options for aftermarket stereos. since my dash is already falling apart, I ended up cutting part of it out to allow the bezel made for a double din stereo install. I'm not fond of the angle it mounts it due to the glare the sunlight puts on it were you can't see the screen that well. I went on the hunt for a single din unit that had one of those double din'ish screens on them that was adjustable.
Finally found one that I could tilt down so it actually would face you flat but it's one of those chineesium units on the jungle site, not sure I want to go that route. Way too much creative modifications for me to possibly mount one in the factory spot next to the gauges for me to even try. I like the bigger screen for use with my phone and the map navigation. Otherwise I would be happy with anything that would BT to my phone for music. I've been pondering the idea of trying to copy the design of this dash building it from wood. then possibly making a slightly larger area below the center vents to allow one of these stereos to sit straight in the dash there. I'm hopeful I will run across a "junk" dash for one if these just for the inner steel section to build off from. since most of the dash are all flat surfaces other than the section the houses the gauges, I don't think it would be too hard to do using oak 1x8's and some oak trim pieces with some steel structure underneath. it would be certainly one of a kind if I could actually pull it off LOL.
I’m inside right now so I can’t take a pic, but here’s the post from when I installed them.Can I see the gauges above the radio?
Here’s the post showing that pod I made and with the gauges I originally had in that spot.Can I see the gauges above the radio?
Will do.Nice if you have to pull it out again could you please get some dimensions
