Yes they do. Isn't that weird!!?? I think it used to be some kind of logging truck, so maybe that was for dragging logs?Just noticed it, but what's going on with that front bumper? Do those pipes with the hook slide out?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Good to know!Ya use it to carry long items such as 20' rebar or small diameter pipe. Another on the rear and you tie on the material to secure it. We used to build them all the time for construction companies here.
You know I don't like doing these the easy way.....That's a PIA job on top of the PIA job to get there. (Hydro booster swap)
You know I don't like doing these the easy way.....![]()
Nice! Who doesn't love a homemade present? That's a gift from the heart right thereThat would be the hard way, the harder way, and "we gets to do this over again". There is no easy way even with power tools. The do over is from other failed parts like a PS pump dusting the system as it eats itself alive. I gifted a homemade snow globe to the parts store manager: Power steering fluid from the dusted system in a jar = snow globe. Replaced entire system: hoses, box, booster, and flush cooler...
Oh yeah, now that you mention it, I forgot that was a problem. Good thinking doing the relay mod right now. Thanks!For the headlight plug, that's pretty common.
Plenty of trucks burned down from that. And the cruise control cutout switch on the brake master cylinder.
But look into doing the relay mod for the headlights. It's two-fold. One it takes the load off the headlight switch, two the lights will be brighter.
I am going to check it for vacuum when I get home. If it still has vacuum then I'm good, but if it has lost it then yeah, I'll swap it.Exchange the accumulator. Moisture in the system isn't worth savings on an accumulator. If you are going through all the trouble, and you are, no need to cut corners now. I would draw a deep 30 min+ vacuum on the system with the current accumulator and then bring it to 0 PSI with R134a. (This step makes sure it will hold a vacuum in case there are other leaks.) Then swap the accumulator, vacuum, and charge.
