Big T
What do you mean “quench”On the handles and rods for opening the doors:
We kept the handles in stock in the fleet. Diagnosed properly: the rod unbends itself. Then the handle maxes out. The common action is people pull the handle with fingers and that elbow gets used as a fulcrum to lever the door open. Quickly comes the bent handle.
One of the guys made a set of replacement handles from steel. The rods just kept un-bending and the problem continued. Ever notice on higher mileage the outside handle has to lift more than originally?
So the same guy who wanted something fixed once & never again got into the rods. Took them out after figuring the perfect shape to be in. Heated the bends with a torch and quenched them. Now they will never bend again. So we all watched him do it, then wondering about it… had him do the rod quench to rods on a driver door of a new truck for a rig that had extreme use- about 30,000 miles each a year (60k total), by a pair of hyperactive drivers that who were in and out of that door probably 40 times a day each shift. The handle still bent but it took a lot longer. Those two guys normally Got a new handle once a year. We didn’t have to replace that handle until a few months before selling the truck.
Idk if it’s worth the effort to pull one, quench it, then reinstall it. But if you already have one out…
Doug: just like all gm… get the locations from the manual and hit all the grounds when you get a shot. Put some No-lox on them while you’re at it to help a little bit.
It? Drop it in water?
