MrMarty51
I believe that AC Delco might make their balanced flow pump for that system.Its a multi belt/pully system, it's not just a singular belt if thats what youre asking
The multi V belt system drives the coolant pump in the opposite direction as what the single micro groove belt does.
So the flow cooler or any of those other pumps will not work on Your truck.
It has to be the pump specifically designed for the V belt system.
