1994 K3500 extended cab dually
Nice work! the only thing I would be worried about for the future is the flex joints. when the day comes they start leaking and you need to replace. iirc they make them with v band flanges so that they could easily be replaced, wonder if you have clearance for that though.
Though on my 95 I just about had no choice to cut my down pipe and splice in a 4" steel flex pipe to alleviate the stress and from it banging the frame to the 4" exhaust kit I installed. It's been on there for a while now, all rusted but still holding up LOL. your stainless should last for years to come!
As long as I make my cuts straight, it won’t be bad to replace them in the future if the need ever comes.
It took 2 days, but I finally have the post-turbo exhaust done (mostly).
I installed an FTE Diesel muffler/resonator on it again because the sound was great and I had zero drone in the cab. It’s 409 stainless.
All tubing is 304 stainless. I started TIG welding all the joints. Oof. That took so long and I wasn’t happy with the results - not only did my beads look like crap, but I’m also not set up to backfill the tubes with argon, so I wasn’t getting great corrosion resistance anyway…..so I ended up welding all the joints with carbon steel MIG and was much happier with the results. The downpipe starts 3” and transitions to 4” before the flex joint. I left the end of the exhaust unfinished so I can make the tip align with the bed how I want and not have to rework it after the bed is installed…..I learned that lesson on the red truck.
I sandblasted the manifolds and hit all the welds on the rest of the pipes with a stainless wire wheel. After that I painted the manifolds, crossover pipe, down pipe and resonator/muffler with KBS Xtreme Temperature Coating. And finally I wrapped the crossover and downpipe with DEI header wrap. I installed the manifolds with Stage 8 header bolts so they won’t loosen up. I also wrapped the starter with some heatshield material I had in stock already. It’s ready for the cab to be installed now.
IMG_2307.jpegIMG_2308.jpegIMG_2309.jpegIMG_2310.jpegIMG_2311.jpegIMG_2312.jpegIMG_2313.jpeg
Nice!!
question, how low does that crossover hang (from the ground) I assume you are planning for suspension lift or tall tires for offroad shenanigans.
you can always keep the ones you just made as spares/mockup units and re-make them with any added design changes from stainless, then wrap those LOL 🤪
