My name is Will, get ready to drink from the firehose…
I can’t remember how to tell which is which- just know to VERY CAREFULLY start to thread them in incase it is wrong.
None of the 6.2 had a turbo factory, the 6.5 also started without a turbo- later they are added but were always undersized from GM.
As to using n/a nozzles on an engine with a Turbo- yes it works but it doesn’t work near as good as it can. N/A was 1850 psi and turbo was 2250psi by the time GM figured out which way was up. How much is for mpg vs power vs emissions? Internet arguments #4 & #5. Results are…. It changes based on your set up and use.
This is where learning to diy stuff, having the tools and doing it pays off. Having a turbo on a 6.2 is a customized ordeal. When they first did it, they added a turbo and it made it better, but they left a lot on the table. That small turbo leaves a lot on the table. Idk if it would be worth getting injectors dialed in on it because imo the new injectors will probably outlive the turbo. Generally I tell people redo injectors at 100,000 miles but they will live double that. It’s just that you are leaving mpg and power on the table when you go much over 100k.
That engine is tired. Idk how much longer it will withstand- could be quite a while but in all honesty- I say nurse it along and focus on rebuilding a different engine. Do it correctly from ground up and have it last the life of the rest of the truck.
Being what it is, long term you can justify pumping some money into it because it will be a decent daily driver, then when you tire of it, it will sell for enough to bring in what you pay into it.
With injectors, ideally a guy gets a pop tester and learns to rebuild them himself. Not a hard task, just annoying. You start with two sets, take set #1& get them to pop within 25psi of each other. At say 2200 psi. Build set #2 at 2300 psi.
Install set 1 and test drive recording 0-60 & mpg. Swap in set 2 again recording 0-60 mph & the mpg. Each time you drive it to work & such during the week. Weekend comes and swap the sets. Now when you remove set #1, build them to 2400 psi. You will build a Bell Curve of performance and mpg.
Continue until you see results fall. Image peak is somewhere between 2300 & 2400. Now you build a set to 2350. Now best is say between 2350 & 2400 so you build a set at 2375psi. Now you will have found the optimal pressure for your truck with your turbo in your situation for your purpose. Then you build the other set to match. Now you are set for the for the next 200,000 miles at peak performance.
But understand going from a 6.2 to a 6.5 changes the peak performance.
So can a turbo swap, adding an inter cooler, new injection pump, better air intake or exhaust.
The 6.2 has larger valves than a 6.5. This is always better. Problem is removing 6.2 heads and building a new engine with the old heads- they aren’t always reusable.
You never know what it is until it’s torn all apart. The draw back of 6.2 heads is some are hard to get injector bodies for - the earlier mentioned different threads.
Also the larger valves in the 6.2 that help with mpg and power… crack easier than the 6.5 smaller valve heads. But if I was building an engine and had both 6.2 & 6.5 heads in good condition-I’d use the 6.2 for the valves. You can spend a pretty chunk of money and have 6.2 valves cut into 6.5 heads but it isn’t worth it unless you are doing a top end build.
Your turbo being undersized- run it until it dies but save up cash to replace it. An hx35/40 hybrid is probably your best bet.
Try coming up with a used inter cooler from someone with a newer truck who upgraded their stock one for a high performance one is the normal money saving move to get one. It goes in front of your radiator, has air go from the filter to the turbo. From turbo through the inter cooler and to the turbo. Colder air is better for everything always in an engine for both mpg and power, better to avoid overheating, helps keep engine oil cleaner, about the only thing it can’t do is skin you deer for you after you bag it. Drawbacks- $ & time to install, more stuff innthe way when working one engine. More things that can break and need repair. How good is it? There is not a single turbo engine diesel or gas that doesn’t have one factory now, It is a definite worth while investment.
So…
What to do now? Probably just drop in stock injectors. Get an estimate how much to adjust the set to within 25psi of each other. It is ALWAYS best to have them balanced. It helps all engines and doesn’t matter if mpg, power, long life, emissions- it helps them all. But if it’s enough to pay for itself or how long it takes depends on cost they charge and how bad they were to begin with. So roll the dice when ya feel lucky.
