The two stroke dye won’t cause any issues. I’ve run it many times. Red dye diesel also will not cause issues.
I didnt think the stuff in the pail looked dark enough to cause problems.
Right now I just can not make up my mind.
So far to pull this pump and install my original unit all there is is the turbo, fuel lines to the injectors, then fuel hose, IP gear bolts and the mounting nuts.
If I install the intake system, right now dont take too much and then if it still cuts out and makes lots of smoke like its doing then it all has to come apart again.
I used to take magnesium and whatever else is recommended for leg cramps and charlie horses. That caused the pain and frequency to triple up.
I stopped taking those supplements.
Now standing on these blocks of wood the cramping and charlie horsing is at an all time high. When I quit for the day, get in the house and in my spot, them darn things strike with a vengeance.
But enough of the whining, guess I’ll install that lower and upper manifolds and see how it runs.
Just curious, should I use the used gasket or install the new unit ?
Screw it, new one itiz. I’ll have another new one come Tuesday. 😬🫣😹😹😹
I've frequently reused the intake gaskets. I was told years ago to grease them.
I've since been told otherwise. But grease still seems the way to go
I've reused intake gaskets several times. Just inspect them good. On the dye some people have issues others don't. Don't know what the variables are , maybe fuel quality, maybe optics.
At the local rank farm they used to treat each tank as it wrnt out.
Sometimes it may have got a double dose or more.
I've never heard of die messing up an.optic sensor, but I wouldn't rule it out as a possibility.
I've had luck eating dill pickles for the cramps.
WWhen draining the T there won't be lots of water in there. Sometimes you will see a little crud. Sometimes a few water balls on the bottom of the container.
It might depend on the fuel or additives if the water is absorbed into the fuel, so you can't.
What you have there looks good to me.
Later, turn on the luft pump and run fuel through it again.
Since you just bled the T drain. You shouldn't get anymore air
Before going any farther.
I fired up the engine and run it one more time.
The engine accelerates just fine up to about 2200 RPMs, it runs a little rough and makes its smoke to about 2600 RPMs.
After that up to 3000 RPMS its smooth as can be and nor more smoke.
Going to install the intake and run it for a while. Going to try daily driving it for a while but make each trip long enough to bring the engine up to operating temps.
Get some of this fuel used out and add more fuel whenever it gets to about 3/4 of a tank, keeping it to the full side but adding more clear as it goes.
Probably run it around the interstate loop before dropping into work in the morning, use co. Truck for noon time 1/2 hour dinner then another run at quitting time. Probably put on ten miles out then ten back.
Thats the plan, how the engine runs will determine any of these factors.
It's been a little while since I posted anything. It's been HOT and HUMID lately! it's time I get my brown truck driving again. been sitting for the last three or so months and haven't wanted to drive it due to the AC being out. I'm not quite ready to drop the 2 bills yet for a replacement compressor, but I have been looking at them. what say your guys about the two different types available for the crappy R4 compressors?
They make the old piston type and the scroll type. I've heard that the scroll type last longer due to less moving parts but they don't cool as well at idle. then the piston type that cools good at idle but have a short life. Honestly I have been really lucky on the black truck only to just connect it back up and charge it last year and has been cooling great all year. it has a reman piston R4 compressor on it. I have been considering going out to the pick a part yard and snagging one that looks good for about 1/4 the price of a new one just to get it going, or try dismantling the one I have and re-seal it.
Lately the black truck has been having some blue smoke coming out from the tail pipe and I have noticed some power loss along with decreased fuel mileage, getting a little more stubborn to start too. 10 seconds on the GP's is barely enough time for it to fire up. my gut is telling me she's getting really tired. I want to keep it running, don't need a dead vehicle in the yard! at least until I have the funding to source a replacement engine.
anyone have any experience with those scroll type compressors?
I was going to post up the numbers on the AC gauges from My truck to hopefully get it so the clutch dont cycle so often but with this bad run of injection pumps it has not run long enough to do much of anything.
Tonight finished installing the intake, turbo and inner fender and the air filter system.
I forgot that the air filter box, cover and air filter was in the back of the truck.
Rained for more than a day. AF aint much good now.
Without the air filter, revving the engine, it now jas a very slight stumble right at 2200 RPMS then kicks in and runs mighty smooth like.
Tomorrow I’ll get a new AF then take the truck for a drive, see what happens.
Oh yeah, that new old stock injection pump was kicking that P0251 code right off of idle.
I have had this pump fire up this truck at least a dozen times and brought it to Operating temp at least four or five times and it has not yet tripped a code. I’m thinking its the optic sensor in that new pump.
I’m also thinking that the slight hesitation in this used pump could possibly be the advance stepper motor.
I do have a new stepper motor on my original IP that I could try on this pump.
Took the ‘99 Suburban in to have the wheels road force balanced and the alignment done. They had to dismount the tires and vacuum out the balance beads in order to do the road force balance properly. Results were a significant improvement, though there is still a tiny pulse at speeds of 70 to 75 mph. The steering is very tight and the wheel went from slightly clocked left to slightly right. Overall it’s pretty damn good.
I believe the remaining pulse may be from the slight feathered wear in the tires from prior to road force balancing. I will try rotating the tires.
The plan is.
After work, take the truck west on I-94, 10 miles, to the local access and see how it does with that, if it runs good then continue on for two more miles to the Moon Creek exit.
Turn around there and come back to town.
If the truck runs and performs as it should then taking offa working tomorrow and hauling this load to Sheridan Wyoming then on the way back making that rough drive into the cabin.
I am beginning to have my doubts if this truck can make it any place without something breaking. 😬🫣😹😹😹
Too tired after work to do anything.
No test run tonight.
Not going to the cabin tomorrow. Son tlod me they got a lot more rain over there than here, be mighty rough sloughing through the mud to get into there.
Follow up work from the recent half-shaft / lower shock mount issue from last week. Took the incorrect replacement half-shaft the Omak WA O’Reilly’s sold me back to my local store. They requested the correct one from another store and when I went back to pick it up, it hadn’t been delivered and nobody knew anything about it. I just drove over there and got it (10 miles). Later, I saw my card statement and the store had only refunded me the difference in prices and so, I’m owed either another half-shaft or the balance of the refund. Don’t like doing things twice when I mess up, let alone covering other’s mistakes but, that’s life. Probably says somewhere in the Good Book that I should be forgiving of other’s on their life’s path of learning curves. Anyhoo….
I inspected the passenger side shock bolts and they were good. Now, just waiting to find the right parts to reverse the lowered differential mounts from the old lift kit that’s given BigT plenty of ammo to poke fun at my front end over.
Well you can always make fun of my early locking left rear wheel, or my dash that’s shaking apart from front end wheel vibration at 70+ mph, or the rattles inside my driver’s door, or my Pioneer head unit which only partially works in many respects.
Or my ABS which works infrequently (less than 10% of the time), or my transfer case which now has 3 of 4 settings working, only missing 4 Low, or my formerly variable speed wipers which now only has two speeds and decides to shut off only when it feels like it, not when I shut it off.
Took the truck for a short drive, thats with the injection pump I purchased from BlackHMC4 on the Hummer Network Forum.
Took the truck for about a ten mile run.
No codes and the truck seems to be running just fine.
Longer run coming right up.
That's awesome. I hope it keeps working
