1. Will do, we let it sit overnight so we'll inspect all fluid levels as they're "true cold"Keep a close eye on engine oil level.
Normally a sudden start of smoking, you look for loss of turbo boost somewhere like wastegate not working, the hose from turbo to intake leaking out air, etc.
Going up in elevation dramatically, it’s normal to see some loss of power simply because it is getting less oxygen so guys in higher elevation have the manual wastegate adjusted a little tighter to help out.
But to smoke at idle suddenly, that is not normal, it smell the smoke. The odor will tell you what it is. Oil, fuel, or antifreeze.
200° for a long time is no problem- so long as that gauge is accurate and you were 100% full of coolant. Some temp sensors will maintain last level if coolant is lost.
What is your normal temperature? Are you using the factory gauge or a high quality aftermarket one?
Check them waste gate linkages.Oil, coolant, and transmission levels are well withing operating limits
It DID not like being started though
Also the exhaust mainly smells of unburned fuel, and a tad bit of oil due to the leaks (that's always been a thing though)
Whats the boost gauge doing ?My PyroMeter isn't working anymore
It was fine yesterday
Return line ?
Looks like it, no idea now, we're 5 hours away from my installation now, is there a way to cap it off or? Just barely touching it speaks diesel everywhereReturn line ?
Sometimes the injectir halves will work loose from one another and begin leeeeking between the two halves.
