New Optimizer Long Block
I finally got around to tearing down the bottom end yesterday, I was delayed by good weather allowing me to work on my highest priority project, a retaining wall. Well it got rainy and cold again yesterday so with replenished propane I got to work in the garage. I looked over this whole block and the only flashing I see is in the drain back holes between the lifters, here's one of them, they all have it:
There is also a little bit on the end of the center line here, this is the worst one all the others look pretty good:
Is that all there is or am I missing something. It seems ridiculous to me that they would leave that in there when it causes so much trouble and there is so little to do to remedy it.
Not to change the subject, but on your bearings. I see the copper showing on the thrust bearing, but am I just seeing things or do I see copper also showing on the surfaces that ride the crank journals too?
Yes that is flashing. It costs labor for it to be removed and management can’t tell when it should be 10 minutes or 2 hours on one engine. It just depends on the amount of warranty (lost profit) when they address it and since the military almost never does that- they don’t sweat it.
I will say: yours is a pretty clean cast job. Take pics of all the angles and we can look over if there is anything you missed. You get to show off your finishing skills and we get to play where’s waldo. Haha
I found a lot more flashing in the heads:
The orange color on the edge of the bearings is a paint marking from the factory, they all have it. The trust bearing definitely has exposed copper:
Here's the journal it rides in:
The bearing surfaces have no exposed copper.
I finally got around to the deflashing this week, the actual work didn't take all that long it was the waiting on tools. I had a nice set of carbide burrs from Northern Tool but they were real difficult to get down into the block drain holes whilst also getting both hands on the die grinder and don't shade the light but get close enough to see what you're doing with these old eyes behind 325s. So I ordered some long shaft burrs but didn't try them for a while because of good weather (the wall), I didn't notice that these were 1`/8" shaft burrs until I was planning to use them, chuck it into the die grinder and give it a spin and they immediately bent over 60°, I ruined 2 of them then tried one in a Dremel it started out wobbly but then balanced itself and I was able to attempt to use it but the Dremel didn't fit down in the block so no go. So I ordered a set of 1/4" shaft long burrs and I deflashed the heads with my short ones while I waited for the next day delivery. Once they got here deflashing the block took no time, the heads took me a while but I'm pretty sure I took off more than I needed too, I always overdo stuff.
Here are before and after photos of one of the four flashing areas in the heads:
Here's where that shard of flashing on the center seam in the earlier photos used to be:
Here are a couple of the deflashed drain back holes in the block:
There was no flashing on the block in the timing gear area but I did find a bit on the cover:
I took a lot more photos but didn't want to overload this post, here is a link to my shared folder with all of them in it if anyone is interested: https://photos.app.goo.gl/juWv2CG4WbCWH9Q99
View attachment 92868View attachment 92869
I've never had long shaft burrs. Do you have a link?
I've used extension with 2 set screws to hold the burr bits.
I thought an extension would make it way too out of balance to control. These were a little out of balance but they didn't bend themselves in half like the smaller ones and once they were working they stabilized.
On a quick search. Mine were similiar to these. Not much slop.
I haven't posted for a while but I spent a few weeks getting things ready to take to @Twisted Steel Performance which I did Tuesday. I put my new water pump on the new backing plate from Quadstar. I cleaned up all the gasket surfaces to get all the RTV off of them. I chased the threads of all the bolt holes and wire wheeled all the donor bolts for timing cover, water pump, pan, intake manifold. Then I bagged and labeled the bolts by where they go. I cleaned up my injector lines with a green pad and mineral spirits, they were really gunked up with cooked on grease. I put my new P400 heads on the block with 3 bolts then put the new valve covers on with 2 bolts. Then I flipped it over and put the pan on with 4 bolts. I put the motor back on the pallet it came on then proceeded to build a support for the crankshaft. I nestled the camshaft into a couple pieces of styrofoam and drilled through my plywood braces to put zip ties through to tie it down. I screwed or zip tied whatever I could fit onto the pallet. I glass blasted my coolant crossover and intake manifold but I ran out of time before I could do the exhaust manifolds (I'll do them after it comes home before putting it in the truck.) I boxed up the pistons with rods attached by making cardboard dividers to keep them from rubbing each other and I wrapped the connecting rods with bubble wrap to keep them from wearing through the dividers. Most everything else went into a storage box that rode in the back seat of my Tacoma, exhaust manifolds rode on the floor in the back and the piston box fit perfectly on the floor of the right front seat. I built a box around the pallet as I could see no good way to tarp it, it turns out the box was definitely needed because it rained most of the 2 1/2 hour drive to SC, sometimes extremely heavy. I hoisted the engine box into the back of the Tacoma, put the lid on it and tied it down tight against the front of the bed. I put my old block in behind the box stood upright on the back, I double bagged it with trash bags and spiral wrapped them tight so they wouldn't flap around too much and wear themselves out (it worked.) I tied it to the closed tail gate and had 1/2" between the block and the box (crew cab Tacoma = 5' bed.) I didn't take a lot of pictures but here's what I have, the piston box was a preliminary picture while I was waiting on bubble wrap, I fixed those dividers and taped them down and to each other:
PXL_20250429_193145843.jpgPXL_20250507_160241585.jpgPXL_20250507_160251088.jpgPXL_20250507_160301266.jpgPXL_20250507_160321054.jpgPXL_20250507_160338940.jpgPXL_20250507_160407263.jpgPXL_20250507_160457469.jpgbb8bdc54-b558-42fd-89ce-57876f9dca0c (2).jpg
