jrsavoie
Recruit
They seemed absolutely perfect.There was no issues with hard to start or anything else ?
If not then that might be the direction that I am headed.
My injectors tested out at around 2000 psi. give or take a bit. If I'm going to 18:1 compression pistons and planning to put in the injectors to run for the next 100,000 miles (I'm not planning to test different pressures - I don't have the time or patience), should I have them bumped up to 2300? 2800?
@Rockabillyrat tested for me and will be doing the work.
God bless you for trying on this. Those Bosch Marine injectors were well worn. I can say based on feel there was a bit more power with the Marine, but also a lot more black smoke. The power increase was not huge, but you could feel the difference. For me it was not worth the trade off of increased smoke as that is essentially dirty power. My mileage has increased 1.5 mpg with the stock Bosch inhectors.Well I figured I would dig this thread back up since I have started playing with some injectors. I also have to give @MrMarty51 and @Big T a shout out for helping me make this happen and get going on this.
I know Big T and Will still wants to know about those old marine units, I have not messed with them yet, not until I can reliably get better at this.
After taking a couple injectors apart that were gummed up, nozzles stuck together, and full of varnish. I tossed them into an ultrasonic cleaner with some water base degreaser at about 140 degrees for 30 minutes. all the parts came out very clean, the housing looked like it had been sand blasted and the inner parts were shiny and clean.
I put them back together and tried testing them but their spray pattern was not that great. I'm wanting to figure out if the nozzles can be saved yet. Not sure if I can lap the pintle in the nozzle. I've been searching online for more information on this but not finding much at all.
I did try messing with one that seems to spray decent but not sure if I have the technique right on the tester. pumping it like I would using a bottle jack they seem to chatter at a lower pressure than if I pump slowly. a slow pump and they will "leak" or piss at higher pressure, but after chatting with another fellow member, I have the technique just need to work on pressures more closely.
I found some shims on the jungle site that measure 6mm ID x12mm OD I want to see if they will fit into the housing. taking the ID measurements I got 12.2mm. if not the next size available I found was 10mm OD. Being the actual shims are 11.5mm OD we shall see.
also got a hand full of 5mm flat washers from work that are roughly 1mm thick which I can sand on a flat surface to possibly stack and achieve the total shim thickness when using the thin ones. From what I have read online folks are using shims to adjust, then measuring the total and are going back in with washers sanded down to the same amount in order to save on some of the shims that are hard to get.
as of right now I have one that I have been playing with to get the right pressures also to learn on the technique pumping on the tester.
I did a short video of the one I've been working on, right now it seems to be popping off but has a pressure range as I am stroking the pump. Note that with this now shimmed to about 2.06mm thick if I slowly pump the tester, pressure will climb up over 2500psi before it "leaks" I believe it needs to have another small shim added yet.
Here are some pics and a video. On the pintle, take note of the discolored area and a flat spot on the very tip. Both injectors I have pulled apart have this same flat area, not sure if this is from wear or how they are made.
Please chime in with your knowledge
You wouldn't happen to have any photos on the grove wear? I think I need to get me one of those magnifying light up units that clamp to the bench to help me see the tips better.The nozzle without a tip on it is a marine nozzle. Most of the nozzles I pulled apart were very worn with a groove worn into it where it seals. I did buy some diamond paste to try and lap them but never found any I deemed good enough to bother with.
