dbrannon79
I'm getting there!
Here is what it looks like after one 30 minute cycle in the ultrasonic cleaner. take note of the nozzle and tip. the tip is shorter and has no flat spot on the tip. Not sure if the marking on the nozzle is heat discoloration or carbon, but it also seems to have some etching on the side where the part numbers are. I will run it through another cycle and see if it cleans up any better, also get the part numbers on both the body and the nozzle after the second cleaning finishes. I also measured the shim washer too, it seems to be the same as the non-marine injectors.
