Where Did I Take This Off From ? ? ? ? 😹
MrMarty51
Miles City, Montana
I remember removing this bracket but now I can not rememer just what position it came from.
I tried a search using the part number and I can find pictures of it, and also of an entire PS mounting bracket but no explanation of whence this unit belongs.
It does have a slight rub mar on the tab that hangs out 90* but I cant find, or, remember just which bolt location it came off of.
I was thinking it was fairly low on the PS pump side.
when I searched the part number I found this image. not sure if this shows this piece but I'm wondering if it's part of the bracket directly behind the pump maybe something to do with the slot in that part?
Found that photo on the web, thanks anyway.
You could have come off with quite a line on that one.
Maybe something like:
Yeah, twelve degrees below zero and snow four foot deep, had to use about two hours to shovel the snow away, then on with the Car Hart Arctic extreme bibs and coat to crawl under there and got a ton of snow falling on My face and blah blah blah blah. 🤡😀😹😹😹1731420102350.png
But regardless, i do thank You.
