cajun4x42006
Member
need some help to correct my tire size its throwing off shift points 06 GMC dura/Alli 4x4 efi live w/35" toyo MT's
If what you have is a Flashscan, you can just download the V7.5 or V8 editor directly from Efilive's website, and edit your tunes. If you have an Autocal, you may need to get that unlinked from your old tuner, and relinked to a different Flashscan before you can use it.LennyDmaxguy
I only have the handheld I do not have the gear for the laptop
My son, his Dodge, tires was getting wore down.Do you have an Efilive tool already? If so, read out your stock ECM and TCM tunes. Adjusting the tire size parameters isn't terribly difficult. You can likely do it yourself.
I will see what I have when I wake up from night shift.If what you have is a Flashscan, you can just download the V7.5 or V8 editor directly from Efilive's website, and edit your tunes. If you have an Autocal, you may need to get that unlinked from your old tuner, and relinked to a different Flashscan before you can use it.
