DieselAmateur
Thank you @Dustin Zynda. I've had this conversion on the long list of projects and have been leaning towards using the GMT800 LCAs just so I don't run into the same fate of having a GMT400 LCA so worn that ball joints have to be welded in. I'll still probably use the GMT400 UCAs as I seem to go through ball joints quicker than the average user, and welding the upper ball joints in my application would be a more expensive replacement later. And now thanks to your info I know there's an alternative to reaming out the knuckle for the tie rods too
One more question- I see you shared an image of a 3/16" to 1/8" npt adapter. Is this for the front brake hoses? Some folks who have done this conversion have reported that their old brake lines/ hoses bolted right up. Can you provide info on the brake hose size of the GMT800 caliper and how you connected it to the GMT400 platform?
