dbrannon79
I'm getting there!
Torque wrench no required, but a torx bit or screw driver to fit those screws yes. watch some vids and let the others respond before tearing into it!That’s extremely helpful. Thanks for explaining it all. I was wondering if I’d be able to do it myself… to be honest I’ve tried to rebuild my turbo before & was unsuccessful. Thinking I may have better luck with this if I do my research and take time. I’ve contacted a local shop that rebuilds Them for parts & a quote on rebuild of that portion. I think I can do it myself tho…
I do not have a torque wrench/driver tho… is this 100% necessary to reinstall those torks??
Thanks for all the help guys!
I figure it’s a blessing I’ve got it apart and see the leaking diesel… it’s so slight now but an engine fire down the road would be devastating. This is a vehicle I travel/ live in.. converted school bus
I have noticed when I pull the sensor- the truck dies…which leaves me scratching my head as to why I’m having ground issues still.. when I play with that area I can get the glow plug to click rapidly…It’s hard to tell with my lack of professionalism, but it seems the two are closely related..
When I check resistance between negative battery post and cable I am getting .65 on auxiliary battery & ~ .26 on the battery in bay… Does this mean anything to you guys?
as to the wire and disconnecting the OP, yes it will kill the engine. the PCM reads the timing and rpm from that sensor along with the crank sensor at the crank pulley. clean the area off with some brake cleaner (not getting any into the upper intake) check to see if the leak is there or on the fuel shut off solenoid (round thing just to the right of the sensor)
with a leak, DO NOT run the engine with the lower intake removed. if already pulled, re-install the lower section so that you can use and flat piece of board or steel plate the choke off the engine in the event of a RUNNAWAY condition!
moving the harness in that are and the glow are acting up says there is a short in that area of the harness. most likely insulation has been saturated with oil and fuel where the wires are bare and touching. you'll want to get in there and pull the covering off tracing each wire looking for a bare spot and shorts.
as for the resistance on the battery cables, take a look at the crimped lugs on each end and see what condition they are in. look for any corrosion. remove each connection (battery and other end) and clean well both the cable end and bolt / stud where it connects at, then re-test.
