When You are driving, aftdr the engine comes to operating temp, You should be aboe to count the four gears of the transmission then a feel like another gear. It could also be three gears of the transmission, then the TC lockup and then another gear of the transmission.It's running and getting around which is awesome...but when I first put this tranny in the dragging feeling it's had for a long time went away completely, and it felt like it's old self again...but last to days it's coming back..I'm honestly at a loss as to what is causing it...I'm almost thinking that maybe the truck is running the tranny in limp mode. Cause it will be running great, then for no reason I can figure out it starts feeling like it's dragging a trailer or trying to take off in high gear. That's best I can think to describe it
That too was My thought. AKDD mentioned that the ECM/PCM is capable of powering the LP even if the OP sensor is out.@DieselAmateur I've had this problem for a long time now. Before I did the custom tank. And I've changed the filter and lift pump multiple times. No change...
O.p.s. is possible but not sure how to check that..my other thought is that there's a intermittent electric problem causing the lift pump to work then not then start again.
But that's just a thought
this is the one I bought from amazon, but this was before I learned how Dorman parts were junk! I would check on @RockAutoLLC to see if they offer the GM Delco part. plus the 5% discount for us as members of the forum@dbrannon79 . What was the name of that sensor and how much did it run
