Kennedy Diesel fan clutch. Purchased end of 2019. I have never heard the fan kick in.
As recommended by
@Will L. I purchased a heat gun and screwed the fan clutch onto the WP shaft.
I began heating on the outer diameter of the clutch. Slowly rotating the fan to heat the clutch evenly. It finally came up to about 150 degrees on the forward side of the clutch. The bimetal spring was about 160.
I finally started timing at one minute intervals then turning the fan two blades, one minute of heating then two more blades. I did this process for about five rotations but could not get much past the 160 degree temp.
Changing to a minute and a half then moving three blades really increased the temp.
I could get the forward half to about 190 degrees, the back half to around 170 and the bimetal spring to 220 degrees.
The fan never did lock up, it remained at about the same resistance all the way through the heat procedure.
I dont know if the back half has to hit the 185 degree range in order for the clutch to properly engage.
Earlier I had contacted Kennedy Diesel about the engine running at 217 degrees and never hearing the fan kick in.
His reply was that the temp ahead of the fan clutch had to reach 185 degrees in order for the clutch to engage and spin the fan.
Any thoughts on testing the fan clutch would be appreciated.
I am thinking that my next step is going to be to lay the wrench I use for fan clutch removal onto a block of wood.
Set the nut of the clutch into the wrench then start heating the fan clutch from the back side with the butane torch and from tje front side with the heat gun and then see if I can get the entire unit up to about 190 degrees and see if it will lock up.
I could too pinch the wrench into the vice so that the fan blades would be hanging vertical, just in case that would be the position it would need to be in for proper testing.
Thought, Comments ?
