ak diesel driver
6.5 driver
So your not using the factory bulk head connector at all? Also wondering where you got those crimpers? They look a little nicer than mine
This bulkhead is in addition to the factory bulkhead. The reason I have so many extra wires to go through the firewall on this side is because of the addition of the mechanical cruise control and also from rerouting wires so I don’t have a large harness running across the firewall behind the engine.So your not using the factory bulk head connector at all? Also wondering where you got those crimpers? They look a little nicer than mine
Wow $130 no wonder they're nicer than mine
Yes, it crimps the terminal around the conductor and around the seal all in one squeeze of the tool. Now I have noticed that it doesn’t crimp around the seal quite as hard as I would like because you can pull the seal out of the terminal without too much effort - because of that I have been going back and squeezing the terminal just a little bit more with pliers to make sure it won’t come out. I’m not sure if it’s normal for it to have that level of crimp on the seal, if the terminals are slightly out of spec or if the seals are out of spec, but that is my only complaint. The tool has cavities for the terminal to sit in so there’s no trying to balance the terminal in the jaws and no guessing on aligning the terminal in the jaws, so that makes it super easy to work with. The tool also ratchets so it won’t open until you have squeezed the tool all the way, ensuring it has done a complete crimp, which is another nice feature that removes the guess work.Nate , does that crimper do both sides at the same time ?
FAR superior to those crimper/stripper/screw cutter multitools that comes with those multiple crimp connector kits. I have a Klein Tools crimper/stripper that I bought years ago that does a nice job, but I always have wanted (but not necessarily needed) the type that rolls the crimp over on each side to double squeeze the wire like those do. I just can't justify dropping that kind of money ($80-130) on a crimper that I'd use once in a blue moon, if ever.
Nope, not this one. I saw a set that had interchangeable dies, but it wasn’t reviewed as well. However, I probably should look into those options further as I’m learning more about all the varieties. I started put just wanting to do Weather-Pack, but now I’d really like to be able to do most connector styles. I can’t afford to buy a whole variety of these dedicated crimpers though!It doesn't happen to have interchangeable dies for the jaws available for the different size connectors, does it?
