consaka
Active Member
Ok. My injectors were popped to 2500 and I had some hot start problems with my Moose that weren't there with my DS4.
So basically we have two leak point potentials, the pump plungers and the injector. High pop pressure can cause enough leakdown on hot thin fuel that it doesn't want to start? Hmmm
I should think with lower pop pressures you should get more power since more fuel is being delivered.
Yeah setting these pop pressures is time consuming. But as I am only halfway through it, now is the time to reconsider those pressures. Thanks for the heads up on that pump. I have to get this engine done for our trip east to WI. The temptation to just run the current engine is pretty strong. I hate running an untested engine for long trips. I'll be pulling a trailer this time. Maybe I should stick a spare engine in the trailer.
