My question is does your FORD have the speed sensor in the rear axle? If it does, it may not work with the one in the DODGE AXLE. As to the DODGE axle, you have a WIDE variety of wheel cylinders you can swap into it as any of the wheel cyclinders used in 2500/3500 GM trucks will work as DODGE used GM brakes in those years. So you can choose between a 1", 1 1/16", or 1 3/16" wheel cylinder in the rear. I know most everybody who had a mid 90's DODGE complained about the brakes, and a common upgrade was to swap in a set of GM DRW wheel cylinders because DODGE used 1 1/16" wheel cylinders in the duallys while GM used 1 3/16" wheel cylinders. I just looked, the DODGE was listed as a 1 1/4" not 1 1/8" master cylinder. The larger master cylinder piston is just going to reduce pedal travel, but it will actually decrease the amount of braking as it will take more pedal effort to get the same pressure. But that is where the hydro-boost comes in as it can apply more assist to compensate. Knowing how much larger the front brakes were on the FORD than the DODGE, I would put the 1 3/16" wheel cylinders in with the hydro-boost. IF it's too much rear braking, then it's not that expensive to swap in a set of smaller wheel cylinders.
