jrsavoie
Recruit
If you fill the connector with solder, it will get hard as soon as you take the heat away. It's about impossible to crimp it after you solder it. You can solder it after you crimp, but it's a lot more work and hard to accomplish without overheating the cable.
I use heat shrink on the ends.
What did you get for ends?
If anybody sees a deal on Mapp gas torches / presto torches, let me know. Mine are all old, the ignitors don't work and they seem to be leaking all the gas out
