Which turbo would you recommend? I've been reading a little about guys using the hx35 instead of gm turbo. But I also realize the 6.2 wasn't designed for turbo so I know I don't want to over boost it. I'm fine with being slow but I don't want to be so slow I become a hazard on the rare occasion I need to use the highway.
What is the budget? Why the 1987? Why remove the 350?
6.2 NA is slow but fine on the highway until you tow. What are you towing exactly? Wind resistance means more than weight on flat ground.
Could you have an Onan RV generator installed under the burb to provide a/several space heater(s)? Trailer hitch genset? And then drop in a 454 instead of the 6.2. It would be easier and cheaper. IDI's don't like to idle and don't provide good heat at idle w/o a load.
The 6.2 is fine with a turbo esp with the suggested ARP head studs.
Off road low speed is the ONLY good use for a small GMx turbo. It dies at any RPM over 2200 needed to tow at freeway speeds. So a smaller turbo is likely a better choice for you offroad and IMO anything is better than a GMx turbo.
Here is a good turbo build:
http://www.thetruckstop.us/forum/threads/going-mechanical-with-a-moose-omega-marine-ip.45204/
Here is some of my my all out for towing grades build in addition to the article above:
http://www.thetruckstop.us/forum/threads/let-the-insanity-begin-time-to-yank-it.43647/
