n8in8or
I'm starting to wonder if my exhaust is too restrictive now that I'm making more power.  I've been driving around with my windows open, and of course when I'm next to a wall or something I just have to lay into it.  Well when I've done this all I hear is the turbo whistle and more of a "whooshing" sound from the exhaust rather than the V8 growl.  I recently passed my brother on the highway and I asked him what he heard - he also said he just heard whistle.  This is making me think that perhaps the exhaust is too restrictive.  Does this sound right?  I know this could be confirmed with some pressure taps, but before I went through that trouble or started doing additional exhaust upgrades I wanted to hear what you guys thought on that.  Now when I'm hearing this whoosh, I'm at about 25psi of boost, so maybe that's just a normal sound once I'm running that much pressure?  My main motivation for making sure that the exhaust flows as much as possible is that I now have plenty of fuel and the exhaust cleans up overall, but it's still sometimes a bit smokier than I'd like.  Also if I could reduce some exhaust restriction this would help reduce EGTs a little.
In case you aren't able to see my signature, here's my exhaust: The base of it is a Diamond Eye exhaust for a Sub modified to fit the Tahoe, so that means I have a 3" downpipe and then a 4" system after that. The first mod is a 4" x 30" FTE Diesel Resonator/Muffler, this is mounted immediately after the downpipe per their instructions (basically where the factory catalytic convertor was). The second mod is the addition of a Dynomax Ultra Flo 21172 muffler in front of the axle, this is a straight through, perforated-core muffler.
I had already been thinking that I wanted to make a full 4" downpipe. Now I'm thinking that if I do have an exhaust restriction that is my first culprit. The second would be the Dynomax muffler. I tried looking up the cfm specs on the muffler, but I can't find them yet.
As far as testing goes, does anyone know if a standard boost gauge would stand up to the heat and soot of exhaust if I used my old boost gauge to test back pressure? The first thing that would be easiest to test would be to remove the muffler.....it isn't as simple as a straight pipe because I had to weld an elbow to the muffler in order to make it fit, but still easier than making a new downpipe.
So what do you think? Am I worried about nothing? Should I start investigating? Any tests or test methods I haven't thought of or that you've done in the past that I haven't thought of?
