Will L.
A/C components and heater hoses!?!
C'mon man! Performance here- no time for comfy issue to get in the way!
I have the stock DURAMAX downpipe on mine which isn't even a full 3" with several spots where it's reduced down some, then I have the 3.5" front stock section in it back past the torsion bar crossmember, and 4" from there out the back with a straight through CORSA muffler(You can drop a 4" diameter ball straight through it if you wanted to). I know I'm currently in the 400HP range at the wheels, and have gone well beyond 500 at one time playing with a hot tune, and the exhaust never seemed restrictive to me. I know SEVERAL guys have went BEYOND 600HP on 4" mandrel bent systems, even seen one guy do over 800HP on just a 4" system. Even seen where one guy who is using a STOCK LB7 exhaust on his truck with nothing more than a muffler delete(they're 3.5" press bent), did 638HP out of his. So I HIGHLY doubt a 4" system even with that short section of 3" downpipe is ANY sort of significant restriction.
If you do decide to try this, keep notes on how you do it as others might have an interest if the dyno results are supportive
One thing to watch is the transition from firewall to floorboard is typically tight as IIRC the tranny cross-member and rear heater hoses make for congestion. So a 4" downpipe will eat into that already tight space.
And . . . a 4" downpipe will likely need heat treating right away as it will get even closer to the A/C elements than the 3" pipe.
Round to oval then back to round.....
No time for love, Dr. Jones!!A/C components and heater hoses!?!
Sold!! I love donuts, but I'd be hard-pressed to say whether I like the smokey ones or the jelly-filled ones better.With the larger exhaust on my 69 Camaro- the biggest thing I noticed wasnt a big move up in power it was a quicker rev. Even while parked, especially the Camaro. 750 rpm up to 6,000 happened quicker.
I still haven't done the exhaust on my hummer yet. But I did on my other 6.5s. 4" Made a difference in egt. Watching the egt on hills in the Vegas heat and hills is a precurser to ect, so I learned to watch it close.
Don't expect miracles from it, but a dollar to a donut says it will be worth your while.
Your Camaro was super or turbo charged, yes?With the larger exhaust on my 69 Camaro- the biggest thing I noticed wasnt a big move up in power it was a quicker rev. Even while parked, especially the Camaro. 750 rpm up to 6,000 happened quicker.
If long exhaust with a specific sized down diameter was the best choice for power in diesels, i dont think we would see the short, fat stacks in tractor pulls.
Yes, yes it is.it's amazing how much of a difference that 1" makes.
That made me laugh out loud!Yes, yes it is.![]()
Thanks FT!Even with the loss built into the IDI diesel compared to the DI your in a realm where no one else that I know of has really gone on a street 6.5td I suspect you'll find a good solution.
Great work!
