GM Guy
Manual Trans. 2WD Enthusiast
Hey all,
I recall Warwagon having bad luck with the commonly sourced made in China push on braided return lines, and I am experiencing why he hates them.
Previous owner work on the 99 C3500. IDK if they did injectors, or just the loop lines. Injectors are shot, IDK if its the originals giving up, or junk that the PO installed same time as the lines.
Of course it can't be on a local run, it has to be in the middle of Wyoming. Luckily it is not leaking too bad, seems worse at idle (lowest fuel consumption and assuming highest return rates) Under load out on I-80 the fuel economy is not suffering too bad, probably 9 mpg compared to the usual 10.5-11 so rather than mess with it, make it worse, then find out I can't get parts, I am just going to run it and get to the Idaho farm so I at least have a parts runner rig and a cement pad.
SO,
I ask you guys, what does everyone recommend for return lines? I am after quality, not price. I imagine putting the tiny clamps on will be a bitch, but if its the best, I will have no choice but to do it. I would prefer US, Canada, or European (country of quality) lines.
Also, if the clamps are a must, any special pliers to make it suck less? Getting them off the 93 when I did injectors on it, I just used some common Craftsman needle nose pliers. Injectors are getting replaced at the same time, and I imagine I will be pulling the turbo like last time. Glows at the same time of course.
I might have an injector line that has rubbed and is leaking, so I think the intake manifold is coming off anyways.
And of course the J-41550 is in KS, so I will be buying some Kent Moore tools off eBay (Injector socket, GP socket, and line wrench) to leave in Idaho for the next go around, and to help out a buddy 10 miles from the ID farm that just bought a 500 dollar locked up 94 burb (oil cooler lines).
SO,
