NVW
Thanks, you had your issues as well.
Thanks Les, I thought so too when it fired up.Sounds good Leo!
Thanks Matt, it doesn't look quite as good as it did on the stand. It has a bit of grease and the odd scratch you can't see on it from installation.Thats fantastic news Leo! Engine looks great, and I have no doubt you'll have all the bugs ironed out in no time,
Matt
I had ran it before Mike, it was fairly smooth but did have a slight injector knock for about a minute.That's mighty smooth for the first light off !
Simon!!??Oil leak is fixed, it was leaking between the hose and the block fitting. Some dumb ass forgot to tighten the hose up![]()
Simon!!??J/K
I'm regretting I didn't do that when I had the chance. I got under mine the other night when it was running (which is always such a weird experience hearing all that clatter above you) and while it doesn't look like they're collapsed it does move in the mounts a bit. I don't know if it would feel better or worse with tighter mounts. I'm glad you're enjoying your build!The energy suspension inserts really tightened up the engine, it hardly moves now.
When I had the miss fire in #4&5 the engine shook from side to side. Now when I rev it a bit it hardly moves.I'm regretting I didn't do that when I had the chance. I got under mine the other night when it was running (which is always such a weird experience hearing all that clatter above you) and while it doesn't look like they're collapsed it does move in the mounts a bit. I don't know if it would feel better or worse with tighter mounts. I'm glad you're enjoying your build!
My puter don't let me play the vid!It's alive!
Took about a minute for an injector knock to leave. Seemed like a lot longer.
One thing about this block I was disappointed with was the 1/4 NPT oil port feeding the turbo is oversize. I taped it good and it is still leaking, I'm going to try some form a gasket or silicone tomorrow.
It's a pretty small problem overall, the plugs that came with it bottom out as well, instead of getting tight as a pipe thread should. I'm happy with it.My puter don't let me play the vid!
But I'm sure it runs good, them China blocks have a habit of doing that.
Well if there is not always sumtin to complain about..jeez
I practically gave thatta brand new block away and it still ain't good enough..
Get yourself a new fitting( maybe its metric tread), it may solve the problem...the old one could've been squashed to hell by thatmechanic that put that thing together
I did not know, i never checked them on mine.It's a pretty small problem overall, the plugs that came with it bottom out as well, instead of getting tight as a pipe thread should. I'm happy with it.
"I practically gave thatta brand new block away" Cash will do that![]()
