I replaced the hose from tank to LP on mine. After that it would stumble and die randomly. Turned out to be the connection of the hose at the FSU. It was just slightly loose and did not pinch the oring. So air would get in and stall the engine. It was a weird problem because the connection was just loose enough that the fuel could actually create a seal around the oring, but if I hit a bump just right or called for for fuel to overcome the seal it would then leak and engine would die.
Long story short recheck your FSU connections and put new orings in there.
