turbovanman
I has boost, :O)
I'll jump in here with my worthless info pertaining to this as my setup is just like what some say won't work...
My FRC-10 puts out 15psi, I use a cheap 70$ regulator and tee'd into the return line on the frame, it's been like this close to 1 1/2 years now, I haven't blown any lines, haven't had not a single problem as of yet..
I did pull the return line off afterwords to see how much flow or psi there is in the return system and there isn't as much as you would think... I'm no expert here but mine works like I wanted it to....
So your running 15 psi into the pump? We are constantly told that's a good idea, the turbonator guys are against running that much into a DB2. Some forums seem to be hit or miss on good or bad. Have you noticed any change in driving when you did that?
Thanks SC.......Will see if I can find one local, then head to the bay.
Check CL, I was looking to buy one locally as I thought I needed a reg, found an Aeromotive unit for $100, great deal but then I found my issue and didn't need it,
