6.5 carnage
ak diesel driver
6.5 driver
alaska
thought I'd start a thread on just pics of 6.5 carnage. If there is another that I couldn't find mods please merge.
both out of the same engine (not mine). not sure what happened first but it lost a rocker button and the pushrod made its way down to the crank and ceased the engine up tight.
All I have is a few spun rod bearing pics floating around here somewheres.
Then there is a few of me painting one Factory Black... Talk about carnage.. :D
These are from my 98, the damage was done by previous owner.
I have seen some "liquid rebuild" or "rebuild in a can" products. You might give them a try. Its supposed to make the metal real slippery.
:thumbsup: You guys are trying to make me feel good I guess. I am about to see the carnage from the trans behind a 6.5. All of my carnage still ran although they only hit on 6-7 of 8. Makes me feel like South Park. OMG Warwagon killed another 6.5!
This was the first one I killed. Was due to a bad fan clutch and a radiator cap that was defective. It sucked the radiator hoses flat after cool down. The damage was when it let go suddenly under high ECT and shock cooled the cylinder. It went 7K after the damage occurred.
Elk encounter after 6.2 dropped in. :mad2:
Oil cooler painted trailer.
Replacement truck that used most of the parts from above. Engine smoked like it was on fire from blowby and leaked oil out the front seal badly. The driveway was waterproof from diesel oil. Engine was pulled after a summer of towing. Block turned out to have a head bolt crack.
PO did this engine in while towing Payson. Failed injector. 1995 Burb. Let it sit for 6 months. Radiator had this mess in it too.
1995 cont:
turbo.jpg8.jpginj num 8.jpgPICT9318.jpgPICT9319.jpgrabbit hole.jpgbent up push rods and rod.jpg8 holes.jpgcan it be sleeve.jpg
Honest! This was a piston at one time! Really! :hihi:
This engine was running. SES code for injector misfire... Ya think?
Then I had some cheap injectors causing hard starting on the 1993.
Replaced the IP. No improvement so sent an injector out to be tested. The return line worm clamp off the IP dropped into an intake port. Noticed it a week later. Pulled the engine to change the injectors, heads, and pistons. It bent valves.
Arcing in a starter.
Bugs in B99 fuel:
Smoking alternator missing balls in bearing.
PS pump 'reman' failed 30 min after start-up taking out box and hydroboost.
Lift pump graveyard.
AC
Autozone brakes SUCK!!!
My next misery.
I though my 6.5 carnage was good, I agree: YOU WIN
jmiller's 6.5 carnage
attachment.php
Yeah, if WarWagon ever asks to borrow your truck, RUN!
Full coverage insurance, Check.
Needing a new something, Check.
Excessive miles, Check.
Forever having a new thunk, thud, thunk sound, Check.
Less paint, different color paint, primer showing, Check.
Hotrodded in some way when you get it back, Check.
Enterprise Commercial won't rent me a truck - Ever!, Check...
And, no, I never hurt a 6.x crankshaft... Yet.
