Mary was very helpful to me as well. :thumbsup:
Now I have several questions:
#1. The pilot bearing was gone. What is the best to get and where?
use a bronze pilot bushing. i ordered one through jegs both times. bushings cannot fail and destroy the nose of the shaft like a bearing will once it drys out. My uncle, who has rebuilt transmissions his entire life suggested placing a small piece of thick cloth soaked in trans fluid back there to aid in lubrication.
#2. The throw out bearing didn't look to be to high of quality. What is the best and where?
Mine came with my clutch kit. My clutch is a Hays Supertruck and I love it. I suggest replacing your clutch while your in there.
#4. How much difference is there in the bolt patterns to the bell housing between the 94 and 96?
These bolt holes appeared to measure the same. I'm assuming the bolt patterns would be different enough that a tape measure would suffice. No caliper needed.
Whcih side? Motor side would be the same, but there is a change between 94 and 96. 95's IIRC are a one off year for the bellhousing, because they were the 2nd gen trans with the e
#5. How hard is it to swap the shift plate assemblies?
Will it make a difference that my 3rd gear synchro was out on the present trans? What all does this entail? Gasket?
the synchros shouldn't affect the shift rails. There is no gasket, just RTV. Also, replacing synchros is actually quite easy, I did them in my NV4500 in 30 mins (once the trans was out of the truck). There is a special puller and socket for the end shaft nut, but otherwise everything is regular hand tools.
The casting number on the trans we took out is C - 16812
The input shaft is bad on the NV4500 we took out.
I also have a picture of the shifter
